How can I view the loads in these beams/nodes?
Hi All,
I am new to ANSYS Classic FEA and have a simple question.
If I have "scripted" in a few beams w/ beam releases etc, how can I view the loads in these beams/nodes?
They are BEAM44 elements and I have keyopt (6) set to 1; ie., Printout member forces and moments in the element coordinate system.
I have found the PRRSOL,FX command; however, the output is truncatd and I do not know the node number. Because I scripted it, I know the node name; but....
Mark
Mark
