pdf Files
pdf Files
Right here's the situation. Our I.T. blokes away, so because of privileges etc I can't load onto my PC the full version of Adobe Acrobat. I only have Acrobat Reader.
I need to convert some DWG drawings into pdf files. If it's easier, I can convert those drawings into word then into pdf files. Please help!!!
RE: pdf Files
If you e-mail me the files I can convert them for you.
send them to:
steveasmith2000@yahoo.com
Steve Smith
Product Engineer
Staco Energy Products Co.
www.stacoenergy.com
RE: pdf Files
Good luck,
Carl
RE: pdf Files
Peter.
RE: pdf Files
RE: pdf Files
Go to http://www.cs.wisc.edu/~ghost/ and download Ghostscript and Ghostview. Install both per the instructions. If you don't already have a postscript printer go to http://www.adobe.com/support/downloads/detail.jsp?ftpID=1292 and download a "generic" postscript printer driver.
In your Windows application, print as normal expect print to a file using your previously installed postscript printer driver. You may want to change the file extension to "ps" (postscript) or "eps" (encapsulated postscript) as appropriate so that Ghostview will (automatically) recognize the file and open it when you double click on it. Open this postscript file with Ghostview/Ghostscript and use the pull-down menu to convert and save the postscript file to the Adobe Acrobat PDF format. The file is now in the proper PDF format and can be opened and viewed with Acrobat Reader, etc. You could undoubtedly automate/script the process, but it really isn't as cumbersome as it sounds once you've done it a few times (or maybe I've just done it too many times).
Personally, I think both our companies should just bite the bullet and buy both of us a copy of Adobe Acrobat
RE: pdf Files
I read the remarks above but was wondering if there are any
improvemed versions since 2002?
It seems that some folks can edit a pdf file and some can't, depending on how the pdf file was created.
Any advice is welcome.
RE: pdf Files
It seems pdf995 is a good program, it's free.
I used WIN2PDF and it works well, about $45.
And I know there are others.
-Mike
RE: pdf Files
RE: pdf Files
http://www.dwggateway.com/
Steve Smith, C.I.D.
Product Engineer
www.stacoenergy.com
RE: pdf Files
RE: pdf Files
http://www.bluebeam.com
RE: pdf Files
It has detailed text specific to the Agency.
How can I extract the text for a similar
assignment for that agency?
If I scan the file into a pdf file, can I highlight the
text and paste it onto a AutoCAD drawing?
RE: pdf Files
I have "PDF converter Pro 3" that allows you to edit pdf files and it may do what you want. However I found it to run very slow (at least on my hardware) and don't use it much anymore. It may be worth investigating. http://www.nuance.com/pdfconverter/
-Mike
RE: pdf Files
I use pdf995. It will convert any drawing size and is totally free. There is a "sponsor" page that pops up each time you use it, but it's worth it. You can also use it for other windows programs like word or excel. It is like adding a another printer, but it creates the pdf in lieu of printing.
http://www.pdf995.com/download.html
Good luck.
BTW, I am a structural engineer and the IT "bloke". When there are only 3 of us in the office, you have to wear a lot of different hats!
RE: pdf Files
How do you convert from dwg to pdf?
Do you open the file in autocad then save it a a ??? file?
Need more help. Thank you.
RE: pdf Files
RE: pdf Files
My favorite is AcroPlot Jr. http://www.cadzation.com Installing this creates a button in your AutoCAD and you can convert to PDF inside of AutoCAD.
I also use the PDF995 http://www.pdf995.com Just set up the PDF writer as a plot device and you can print to any size you want.
Both of these work well.
RE: pdf Files
It is free software but you get a "sponsors" pop up unless you pay $9.99 (one off fee) if you pay the higher amount of $19.99 you get a couple of other bits of software (PDFedit) that allow you to manipulate PDF files such as combining different files into one so that you could take a full set of drawings and then print them to one file rather than lots of individual ones, very good for say a set of isometric piping drawings for a section of plant.
It has also proved useful for my expenses claims, I can scan all the individual receipts and then combine all the scans into one file and email the whole lot to the USA for payment, previously it was done by hand with all receipts stapled and then posted. Now they will accept one PDF file so everything is now electronic.
RE: pdf Files
RE: pdf Files
www.pdf995.com
I have not had any problems using it. If you do pay (I think) $25 you don't have to put up with the sponsor pages.
Hope this helps.
RE: pdf Files
PDF995 (which I first learned about right here) is a FULL SUITE of PDF creater, viewer, editor software, that's FREE to users willing to let a pop-up banner ad for PDF995 show momentarily. The ad is innocent, takes little room, and clicks away IMMEDIATELY if you aren't interested. I paid the "KEY" charge (~$10 depending...) and got rid of the ads (and visiblity of new products and updates...hmm...). The package is EXTENSIVE, has lots of addable options, and WORKS AS CLAIMED. Search "PDF995", and go from there. I'd give it a maximum user rating if I could. I can't say enough good about it, except just to add- I've taken it with me to every new assignment since I first discovered it, and have ELIMIN ATED PDF related issues from my work day.
Good Luck-
C.Fee
RE: pdf Files
The product is excellent, as users here have stated.
The product is easy to download and configure as well.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
