Phenolic/Foam issue
Phenolic/Foam issue
We are using HexPly HT93 135 C Curing phenolic matrix (HEXCEL), HT93-6k 2x2 TWILL PHENOLIC 285gsm 1200mm more precisely, in some of our new components combine with some strips of Rohacell foam IG51 and we are having some issues with the foam on those components (please see attached document to get more information)
We have checked and we are following the Rohacell supplier specifications for using that foam and we are still getting the same problems so my biggest concern is that the foam is absorbing moisture form the resin volatiles generated while curing the components, as I know that phenolic resins generates lots of vapour water when are being cured.
Have anyone heard about similar problems?
There is a recommended curing profile to allow the volatiles to escape more quickly/easily?
Our current cure profile is:
Ramp to 135C @ 3C Min
Dwell at 135C for 1Hour and 15 mins
Cool to 40C at 0.5C Min
30 PSI pressure at 2.5 PSI Min
Vacuum bag is Vented to atmosphere when pressure reach 15 PSI
Please let me know your thoughts and suggestions to solve the problem, I would also appreciate any information you could send me about phenolic laminates.
RE: Phenolic/Foam issue
From my experience I would recomend using alot more pressure during the cure to evacuate the higher level of volatiles associated with phenolic resin. I would say at least 60 psi would be necessary assuming that this much pressure doesn't damage the foam.
Josh
I would suggest that you do not vent vacuum or apply pressure until your part temperature reaches 100C. The Hexcel datasheet is really bad. It has several blatant errors and little useful information (like volatile content).
Wes C.
No trees were killed in the sending of this message, but a large number of electrons were terribly inconvenienced.
I used to work with a wet layup process that included a long dwell at 71C just to give the reaction water a chance to ooze out of the phenolic as it transitioned through a sticky--> liquid--> gel stage. Without that dwell, the product developed pinholes and bubbles.
Mike Halloran
Pembroke Pines, FL, USA
We are using a new perforated released film with more and bigger holes than the old one and we have also perforated with holes the pieces of foam to improve venting and this seem to be working as we haven’t had any scrap panels for the last week.
I will post again if the problem rises again.
Thanks to all once more.
