Tranverse Leaf as ARB
Does anyone have any experience with a tranverse leaf spring being used as an ARB? The application is a asphalt midget racecar with a beam axle and coil-over suspension, and will be used as a front ARB. Are there any noticible cornering differences as compared to the a standard ARB? Thanks.
RE: Tranverse Leaf as ARB
Goran
Besides, the trick with swaybars is to tune the car by altering the load transfer between the front and rear axles. To do so there must be a load difference between the inner and outer wheel. Other wise we just need different rate regular springs.
Goran
It sounds like the spring pivots in the middle, and that makes it a "camber compensator" used to good effect reducing over-steer on the hind end of swing axle cars like VW bugs and early Corvairs. I think the action is an anti-anti-roll bar, forcing the opposite end to provide roll stiffness.
Yes, but an ARB is still transmitting torque (force) from one wheel to the other, but not to the chassis, even if the centre displacement happens to be zero.
That's very different from your description of a torsion bar attached to a chassis in the centre, which DOES react torque to the chassis.
Regards, Ian
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
how is it that torque is transmitted to the chassis if the the attaching point dosent move?
Goran
I used these on swing axle VWs with two standard front anti roll bars with great success in reducing over steer.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Goran"
Newtons 3rd Law...
Fixing a torsion bar torque reaction point to the chassis is the ONLY way to get a torque transmission to the chassis.
But I get the feeling we aren't quite talking about the same thing...
Regards, Ian
Cheers
Greg Locock
In heave, you get symmetrical deflections and one set of reactions (loads on the chassis) but in roll the deflections are antisymmetrical and the loads on the chassis are quite different (and opposite in direction). A spreadsheet to work up the deflections of a simple beam that overhangs the two supports and is loaded variously at the ends based on beam formulas might prove to be interesting re: the proportions of ride and roll stiffness that are reasonable (or even possible).
IIRC, the C5/C6 Corvettes use such an arrangement, though I'm pretty sure that they retained the sta-bar.
Norm
This is presumed that the swaybar sees exactley the same movement each wheel.
I believe that the "lifting" force thinking of the inside wheel created by the sway bar is a bit confusing, even if right. The bar create a spring wheelrate in roll. If the regular spring wheelrate is 100N/mm it will take 100N to lift the car 1mm one side, and 100N to press it down 1 mm the other side. If we add a swaybar giving 50N each wheel in roll, it will resist roll in the same manner as using 150N/mm springs each side.
The difference is that the spring is loaded in rest by the weight of the car while the swaybar is not.
Goran
Let's compare a car with 150N/mm front side springs to a car with 100N/mm springs and an ARB giving 50N/mm wheel rate effect and assume that everything is perfectly linear, including the tyre spring rate. You also have to assume that all load transfer forces go through the springs (no geometric load transfer).
You could then perform a static (d'Alembert) analysis that indicated that the roll couple distribution of the two cars was the same, and with no jacking forces you could indeed expect to see the ARB position in the exact centre be equal to the no-roll condition.
However, as soon as any longitudinal load transfer, geometric load transfer, single wheel bump or axle bump inputs get involved, there is no way the two cars will behave the same.
I don't know how this compares to the original question, because I need to see a sketch like Greg... I think the 'transverse leaf as ARB' is actually acting as a Z-bar (axle heave spring).
Regards, Ian
I absoulutley agree with your above description. Myself I usually calculate with a bar fuction as such, and dont pay to much attention to f,ex one wheel only deflection or geometric load transfer effects regarding swaybars.
Sorry if I went wrong on the subject.
Goran
