Great! Thanks a lot to Vorwald (Aerospace)
Great! Thanks a lot
   Perfect! Your solution is very good. In fact, I have applied it to my program. The only trouble is I must set the edit box's enable property to 'off'. Thus, I can use the figure's "currentcharacter" property to show the asterisks in the edit box. To do it the user must do click on the edit box, which is no usual. The user don't see any cursor in the edit box as it is usual. The real problem is the edit box have no "curretcharacter" property. Have you any other idea to solve it?
   Thanks in advance,
   Cris
