Electronicly Controlled Drain Valve - MFG?
I am looking for a vendor who supplies an electronically controlled valve that can be used for draining a water tank.  Due to the application, the valve needs to fit in an envelope of about a three inch cube (if possible) and have 1/8 NPT fittings.  The valve will also need to be FDA approved.
Thanks!
RE: Electronicly Controlled Drain Valve - MFG?
Why not use a 2-way solenoid valve?
David Baird
Sr Controls Designer
EET degree.
Journeyman Electrician.
We are currently using solenoids for flow control, but we need a way to evacuate the one gallon tank quickly (<1 min).  The solenoids we are using will take a while due to the .060 orifice.  I'll look into a larger orifice solenoid.
