Isolation Transparency in edit
When editing a part in the context of an assembly, all other parts change to the transparent state I set in "Options". However, if I Isolate several components and then edit a part, I cannot get the other pieces to change transparency. What's up with that? Thank you
SW2007, SP 3.1
Intel Core 2 @ 2.66Ghz
2 GB Ram
FireGL V7100
SW2007, SP 3.1
2 GB Ram
FireGL V7100
RE: Isolation Transparency in edit
I am able to make the whole assembly transparent, which is not what I want. I want all parts except the one being edited to be transparent.
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
FAQ731-376: Eng-Tips.com Forum Policieswww.scottjbaugh.com
Thank you for your reply
