Unable to create journal file
has anybody seen the problem of the system being unable to create a journal file and unable to use the backup feature on SW '08 SP 0.1 - 2.1 on Vista 32 bit?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Unable to create journal file
Jeff Mirisola, CSWP
Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
By default SolidWorks will write the journal file in the location specified by:
HKEY_CURRENT_USER\Software\SolidWorks\SolidWorks nnnn\ExtReferences\SolidWorks journal folders
In SolidWorks 2007 this key is:
HKEY_CURRENT_USER\Software\SolidWorks\SolidWorks 2007\ExtReferences\SolidWorks journal folders
If this is unset when SolidWorks starts then the default location will be used:
{User profile}\Application data\SolidWorks
on a standard computer this would be:
C:\Documents and settings\%User Name%\Application data\SolidWorks
If running the copy settings wizard then this key is part of the copied registry and may be set to an inappropriate location This issue has been identified and reported to the development team on SPR#364811 ("Admin Director Workflow causes the journal file to be set to the wrong directory").
Please check the settings of this key in the user's installation and verify that each user has a separate location set. Verify that the users have full control over the journal file in the specified location.
Jeff Mirisola, CSWP
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
I've seen this problem when the user is new to SW and doesn't realise that it takes quite a while for SW to load after the splash screen's brief appearance; they see no "Eggtimer" and nothing seems to be happening, just the usual pointer and the desktop, so they try again and SW obligingly starts another instance.
I think that this is something that the software writers should trap and maybe ask if the user really want's to run a second instance, but most don't bother!
Trevor Clarke. (R & D) Scientific Instruments.Somerset. UK
SW2007x64 SP3.0 Pentium P4 3.6Ghz, 4Gb Ram ATI FireGL V7100 Driver: 8.323.0.0
SW2007x32 SP4.0 Pentium P4 3.6Ghz, 2Gb Ram NVIDIA Quadro FX 500 Driver: 6.14.10.7756
