Elevations at culvert in HEC-RAS
I'm modeling a channel with a culvert in HEC-RAS. I have an elevation on my profile plot that I'm not sure where it's coming from or how to get rid of it. On the attached picture you can see the elevation inside the culvert. It is the same elevation as the bottom of the upstream cross section. I'm not sure why it's showing up here? Can anyone help me?
RE: Elevations at culvert in HEC-RAS
good luck
