P and ID for centrifugal air compressor
Does any one has a typical P and ID or Process flow diagram for a centrifugal Air compressor, having closed loop or open loop water cooling .
RE: P and ID for centrifugal air compressor
Probably got one for a recip lying about, maybe a turbine type too if I can find a small enough copy of it to scan in. Any good?
Hello ScottyUK,
Please check and kindly let me know if you have one for a turbine type
Many thanks,
Mechatronic
Hello ScottyUK ,
I am glad to download the P and ID. I am very thankful to you and I appreciate so much of trouble you have taken to scan and upload the file
Many thanks once again !
Mechatronic
Not a problem - hope it is of use.
