Length of hose
Length of hose
Length of hose
I've been given a STEP file of a flexible hose by our supplier - its purely the solid model portion, and has no datum axis or curves.
Is there a way in Pro/E WF2 to reverse engineer the component to discover the total end-to-end length, bearing in mind its bent in various different directions??
Lee
RE: Length of hose
Lee,
Create points at the center of each straight section. Then construct your curve. Measure the curve and you'll have the total length of the bending pipe.
-Hora
RE: Length of hose
Hi Hora,
Thanks for your response.  The item only has 1 small straight section at either end, with the rest of the hose being one long continuous curve bent in many different directions and bend radii - I don't know how to create points at the direction changes......
Lee
RE: Length of hose
Can you measure the curve lengths of the wireframe edges of the part. Obvously this will not give the same result as the central axis, but if you can measure 2 diametrically opposite edges and take an average between then you should get pretty close..... I think.
RE: Length of hose
Lee,
You can place planes that intersect the hose at however many locations you need.  I would place an intersecting plane for each bend in the hose.  Next, place a sketched point on each plane.  The point can be located at least approximately on the centroid of the hose cross-section.  Now these points can be used to create a measurable datum curve.
