Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Congratulations for your great site. This site helped me more than university..."
Geography
HAVENOIDEA (Mechanical)
12 Feb 08 9:23
Hello Everyone,
I am looking for a plastic material that I can make a shim and cylinder out of- it needs to be strong enough to support screw threads through its sidewalls, but have low enough friction to be able to effectively slide up and down. Low wear is also a necessity. Does anyone have any material ideas for plastic on plastic sliding? The pieces are for a film thickness guage that uses the Eddy current, so no metal can be near the tip. Thanks in advance.
Benjamin Tremblay
Pud (Mechanical)
12 Feb 08 11:22
Polyoxymethylene, commonly called acetal. Trade names Hostaform, Delrin amongst many, many others. Available in bar/sheet stock for machining or pellets for extrusion and injection mouldings.
Some injection moulding grades are available with PTFE in for even lower friction.
Easy to machine or mould.
Cheers
Harry
12 Feb 08 11:52
Thanks Harry,
Would this material be available to rapid prototypers by any chance?
Ben
dgowans (Mechanical)
12 Feb 08 12:33
Ben,
I'm not aware of an additive RP process that uses acetal (SLS comes to mind as a possibility, but I've never seen an SLS part in acetal).  You can certainly have prototypes machined from acetal stock.
12 Feb 08 13:42
Thanks guys,
Sounds good. This gives me a solid start. Appreciate it.
Close Box
Join Eng-Tips® Today!
Join Us             Close
