Tool for measure dents
Is there any good tool for measuring DENTS on pipe (10"-28") at pipeline. Tool should be simple and portable.
One point measuring is ok (like gauge), but recording profile of dent is also desirable (one axis or two)..
RE: Tool for measure dents
____________________________________________________________
To Measure Dents
Set up a Grid
Place masking tape along the dent horizontally space each 75 mm apart
Do the same in the vertical with the tape 75 mm apart..
Measure
At the center of each tape intersection measure the distance between the straight edge and the can section using a taper gage.
Record
Write the depth at each intersection on the tape and record it on a chart like the one attached.
Chart/Analysis
Plot the data on a contour map or surface map scheme to determine maximum depth and shape of dent.
I also use a General Tools Mfg Co. No. 837 Contour Gage
http://ww
Ludeca has some laser products that can be used in these application http://www.ludeca.com
Vita sine litteris mors est.
