Surface Texture Symbol Data
Is it possible to save out saved styles to a text file... I can only get it to save to the actual drawing file. If I want the same styles across the board I'll have to at present, create and save the styles into each template file.
Any thoughts?
Cheers,
M
Any thoughts?
Cheers,
M
RE: Surface Texture Symbol Data
There is a command that allows you to copy formatting between files: dimensions styles, line styles, face styles, etc. I actually keep a separate file that stores all of these styles and then use the organizer to copy them to the new template files with each release.
--Scott
http://wertel.eng.pro
Thanks for the info. I use the method you describe for the dimension styles etc, but cannot see how the Surface Texture Symbols can be copied across... what am I missing?
M
