What is the selection criteria when choosing between Class 1 and Class
Hello members,
What governs the selection between Class 1 and Class 2 RT film? I've looked into ASME V and it only specify that industrial radiography film be used. It also specifies the density requirements etc. How do we choose between these two film classes and determine whether its suitable for our project? (Usage : Hydrocarbon column for petrocemical plant)
RE: What is the selection criteria when choosing between Class 1 and Class
downloadable from
www.
Class 1 and Class 2 RT films were not found.
Another Document:
Radiographic Testing - A comparison of Standards for Classical and Digital Industrial Radiology
http://ww
mentions:
The radiographic techniques are subdivided in Europe into two classes:
Class A: basic technique;
Class B: improved technique.
http://www.welding-advisers.com/
Reading the Appendix in ASTM E 1815 (Standard Test Method for Classification of Film Systems for Industrial Radiography), it says there that Class/Types 1, 2 or 3 were film types based on a version of ASTM E 94 dated before 1984. In ASTM E 94-83, films were classified (in a SUBJECTIVE way) in order of increasing speed and decreasing image quality (contrast & graininess)...
Film Type 1: low speed; very high contrast; very low graininess
Film Type 2: medium speed; high contrast; low graininess
Film Type 3: high speed; medium contrast; high graininess
ASTM E 1815, on the otherhand, classifies films based on image quality performance based on four MEASURABLE image quality parameters. Speed is not a classification parameter.
I suggest you read ASTM E 1815 for more information.
