corrosion of duplex chrome-nickel coating
Hello all, We have encountered a very serious pitting corrosion in the chromium layer of a Ni/Cr coated steel rod of a hydraulic piston. The nickel layer seems to be fully intact, but the chrome is seriously and very agressively pitted. The corrosion appears, position wise, to be related to a metal scraper ring in the cover of the cylinder, so galvanic corrosion may be an option. Anyone has any experience with similar damages?
some photo's:
htt p://www.te chnofysica .nl/downlo adables/20 080205.jpg
http://w ww.technof ysica.nl/d ownloadabl es/Capture _00010.jpg
htt p://www.te chnofysica .nl/downlo adables/IM G_1099.jpg]
some photo's:
htt
http://w
htt
RE: corrosion of duplex chrome-nickel coating
http://www.welding-advisers.com/
