Dispersion Modelling-1
A small query for dispersion modelling gurus.
There was a dispersion study carried out by Consultant for CO2 from Vent Gas in order to comply with occupational exposure of CO2. Wind Speed has been considered as 1 m/s as input to the model. Client asked to revise the modelling based on 'Design wind speed for atmoshperic dispersion at 5 m/s'. We are about ask the Consultant to look into the same.
Meanwhile I did refer to Gaussian dispersion equation where 'C' (ground level concentration) is inversely propotional to 'u' (downwind speed). From this, will I be correct to state that the 'C' would be 5 times lesser at 5 m/s than what it is at 1 m/s?
RE: Dispersion Modelling-1
I'm by no means an expert, but I'd suspect not.  If I remember correctly, the sigma's are a function of wind speed; when the wind speed changes, different sigmas will have to be used.  This will result in C being something else (i.e. not just 5 times less).
Syl.
