API Macro
API Macro
API Macro
I'm in need of macro that will query a custom property then fire up an worksheet in excel.  The macro would then lookup that value and return another value in that same row and assign it to another custom property.  I've found many macros but they all seem to do the reverse.  Toolworks is a good product but needs a backend database.  Thoughts?  Suggestions?
Thanks in Advanced.
RE: API Macro
If you've found macros that "do the reverse," my thought/suggestion would be to "reverse engineer" them to do the job you want.
