How to find Cg from given info
I have given the Cv as 0.115 and Cg as 27,000 CFH at full cylinder. This is a fisher control valve. Upstream pressure is 500 psig and relief pressure is 425.7 psig. I am trying to find the maximum flow through the control valve. The flow medium is air with 5% Helium. I have a template to find the maximum flow rate. But i need the Cg as constant. Could you please somebody help me in converting the Cg to constant. Stonecold and other guys explained me but I haven't understand exactly.
Thanks in advance
Thanks in advance
RE: How to find Cg from given info
Refer to below address:
h
I hope this helps. You have to make a guess of Cl given the data avaliable. The valve vendor may be able to assist you will accurate values for Cl that they have used. Some just use 30.
