EMD 567 Impeller Removal
Does anyone have any tips on removing a 567C water pump impeller without using an impeller puller?
RE: EMD 567 Impeller Removal
 Try some heating with a gas torch on the impeller center area and immediately afterward use a cold water shock on the shaft. Should break it loose. Probably been Loctited originally.
Offshore Engineering&Design
