Blind thickness Calculation
Is there a formula for calculating the thickness of a piping blind (i.e. Flange, Fig 8, line blind, etc) ? If so, what is the appropiate formula for each type?
Carlos
Carlos
Blind thickness CalculationBlind thickness Calculation(OP)
Carlos Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Blind thickness Calculation
Look at B31.3, paragraph 304.5.3:
The minimum required thickness for a blank shall be calculated by the following equation:
Tm = dg * ((3*P /16*SE) + c)^0.5
Tm = mininum required thickness
dg = inside diameter of gasket for raised or flat face flanges
dg = the gasket pitch diameter for ring joint and fully retained gasket flanges
S = the allowable stress from Appendix A
E = the weld quality factor See Tables A-1A and A-1B
P = design pressure (psig)
and the weld strength factor must be applied if there is a weld in the plate.
C = the corrosion allowance. Also use "C" to allow for impingement abrasion or other wasting of the blank thickness.
Just for clarity the formula given by John is for a line blind fitted between two flanges. It does not apply to a Blind Flange which is subjected to bolting moments.
The B31.3 formula is based on the solution to the differential equation developed by Poisson a few years ago. Since the situation is actually highly nonlinear from both a geometrical and material perspective, the B31.3 formula is also quite conservative. More reading at ht
jt
