coordinate problem
coordinate problem
coordinate problem
Hi everyone,
this is my first post in this forum.
I am doing 2D hemisphere model pressurized by axial load on its surface by writing input file.
For node arrangement:
Node 1 is located at coordinate (43.59,90) at far right-edge of the hemisphere and center is at node 999 at origin.
The problem here is how i could locate node 101 (the far left-edge of the hemisphere) as the coordinate would be (-43.59,90)?
I got error message during analysis job as the coordinate could not be negative value.
Thanks for your help
rgrds
Kaninchen
RE: coordinate problem
I'd suggest that the error you see is because you have 2D axisymmetric geometry and as such you can't have a negative X value, or negative radius as it would be in RZ geometry.
corus
