" Help on context " displayed in Resourse Bar ?
If I push the "help on context" button,the help-windows pops up as a seperate window somewhere on mij screen.
Currently I'am working with NX5 and Windows Vista and I have seen other users working with NX3 that It was Indeed possible that the help on context-window was integrated in the resourcebar.
But somehow I can't manage this in NX5.
Kind regards,
ErikvD
Zebra-cad 3D services
the Netherlands
Kind regards,
ErikvD
the Netherlands
RE: " Help on context " displayed in Resourse Bar ?
One thing I have done here is create a FAQ that I mapped the browser to, works pretty good so far. I've got a lot of plans for a site to put in that browser that I'm going to implement once everyone gets up to speed on using NX.
Now inside of NX all of the items that we launch from the Resource Bar, such as the Navigators and Internet Explorer and so on, if you're running a 64-bit verion of NX, they must all be 64-bit applications since the Resource Bar is executed from INSIDE NX as part of the main application. Now it's possible for a 64-bit version of NX to 'spawn' a 32-bit application, but it will run in it's own window as a sepatate application. So we were forced to move the Documentation functions, which includes both the User Documentation and the Help Documentation, OFF the Resource Bar and onto the Help Pull-Down menu or by launching it as 'On-Conext' Help using F1.
Now you may ask what does this have to do with me if I'm running a 32-bit version of NX 5 on a 32-bit version of Windows? Well we only develop ONE version of NX in terms of source code and then port it to the various operatings systems that we support with only as few platform specific changes and considerations as possible. So in the case of Windows, we developed it so that the same source code can be compilied and integrated on both 32-bit and 64-bit Windows, which means that starting with NX 5, we had to remove the Help tab from the Resource Bar and instead launch all Help and Documentation tasks in their own Window. Also, one of our commitments to our customers has been to always try and keep the different platform versions of NX as close to alike as possible in terms of appearance, location of functions and their behavior, for those situations where we have customers who run different platforms but whose employees may have to move from platform to platform as part of their normal work environments.
Note that this same situation also forced us to move the window there the CAST product runs OFF the Resource Bar and into its own independent Window.
Anyway, I hope this helps explain what happened and why.
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
So,
John thanks for your clear explanation, it saves me a lot of examining effort.
MCGNX Thanks for your usefull tip, it's a nice alternative.
