creating a range variable not tied to a spreadsheet
Here's the situation.
I want to create a user-defined FUNCTION that manipulates several intermediate variables as complex variables. The excel complex functions (for example improduct, imsum, imexp) work on spreadsheet cells.
If I had a sub (instead of a function), I could just create my range variables, and then use a set statement to tie them to some remote unused corner of my spreadsheet, and then use them to store complex values (intermediate results).
BUT, I am using a function instead of a sub. Functions don't allow you to modify the spreadhseet by storing a value.
I could modify my function to call a subroutine, but then I'd have to pass all the other data long with it. Would certainly work, but it seems like a double-workaround
1 - I am having to store stuff in a spreadsheet cell, which I don't really want to do.
2 - I have having to create a sub and pass all my data to it, which I really want to do.
I could avoid these workaround and develop more straightforward code if I could simply create and manipulate a range (or single cell) variable within the function without tieing it to a spreadsheet. Is there a way to do this?
One solution I am considering is building my own userdefined data type for complex variables and then bulding my own set of primitive functions to manipulate these complex variables for complex multiplication, division etc. It would probably not be tremendously difficult. But I still would like to know if there is a way to use a range variable in a function without tieing to a spreadsheet.
RE: creating a range variable not tied to a spreadsheet
CODE
string2="2+3i"
string3=improduct(string1,string2)
debug.Print(string3)
I was able to use the function when tied to a spreadsheet as follows:
set range1=sheets("Sheet1").range("a1:a4")
set range2=sheets("Sheet1").range("b1:b4")
call fourier(range1,range2)
With 1 0 0 0 in column A the above returns 1 1 1 1 in column B (as expected).
I tried unsuccessfully to use fourier in vba without tieing it to a worksheet and got errors each time. See failed attempts below:
Sub fouriertest()
Dim range1(4) As String
Dim range2(4) As String
range1(1) = "1"
range1(2) = "0"
range1(3) = "0"
range1(4) = "0"
Call fourier(range1, range2)
Stop
' Gives error: Input range must be a continuous reference
End Sub
Sub fouriertest2()
Dim range1 As String
Dim range2 As String
range1 = ["1+0i" "0+0i"]
Stop
' Gives type mismatch
End Sub
Sub fouriertest3()
Dim range1 As Range
range1(1) = 1
range1(2) = 0
Stop
' Gives error - object variable not set
End Sub
Sub fouriertest4()
Dim range1(2) As Variant
Dim range2(2) As Variant
range1(1) = 1
range1(2) = 0
Stop
' Gives error - input range must be a continuous reference
End Sub
Any suggestions on how to access fourier from vba without tieing the variables to a spreadsheet range?
Sub fouriertest()
range1(1) = "1"
range1(2) = "0"
range1(3) = "0"
range1(4) = "0"
Stop
End Sub
Sub fouriertest2()
Stop
End Sub
Sub fouriertest3()
Dim range1 As Range
range1(1) = 1
range1(2) = 0
Stop
End Sub
Dim MyArray1(1 to 1, 1 to 4) as string
Dim MyArray2((1 to 1, 1 to 4) as string
MyArray1(1,1) = 1
MyArray1(1,2) = 0
MyArray1(1,3) = 0
MyArray1(1,4) = 0
call fourier(MyArray1, MyArray2)
Doug Jenkins
Interactive Design Services
www.interactiveds.com.au
CODE
Dim MyArray1(1 To 1, 1 To 4) As String
Dim MyArray2(1 To 1, 1 To 4) As String
MyArray1(1, 1) = 1
MyArray1(1, 2) = 0
MyArray1(1, 3) = 0
MyArray1(1, 4) = 0
Call fourier(MyArray1, MyArray2)
Stop
End Sub
As far as I can tell the fourier command will only accept range parameters, which seems strange because most VBA functions are happy to accept an array.
I have a few posts about passing data to/from a spreadsheet range on my blog, which may be of interest, even if it isn't applicable to the fourier function.
http:/
http://n
Doug Jenkins
