What¦s the best CAD product and ver
What´s the best CAD product and version to easily draw beams, columns & plates. Steel reinf & forms (in 2D).
Modern product development is complicated. With streams of data pouring in that inform how...
Download NowINTELLIGENT WORK FORUMS
RE: What¦s the best CAD product and ver
for 2D design problem, the AutoCAD from Autodesk is very powerfull and easy to use. The current version is 2000 or may be 2002, sorry I have only tested the 2000 and migrated to Pro/Engineer, that is more suitable for 3D design. If you want to automate your design intents, AutoCAD provides AutoLISP (like MACRO language) and C++ Application Programming Interface, so it is very nice for you.
Good luck
If you are looking for simple and cheap/free 2d packages, may I suggest giving this site a browse:
http://www.freebyte.com/cad/cad.htm
"Happy the Hare at morning for she is ignorant to the Hunter's waking thoughts."
Sorry. I express INcorrectly my question:
I asked about CAD to USE in 2D (planar drawings) of Beams, Columns, Plates, Reinf & Forms drawings.
In this 5 kinds of applications, I asked: What´s the best CAD to use (in reinf concrete design). Right.
Tks, sorry about my incorrect message.
Old horse war. Louis.
If you only need to draw beams, coloumns, plates, etc, then most of 2D CAD programs can assist you well, especially AutoCAD, it is mainly used in civil engineering adn architec. I have seen many cranes and elevators were designed with AutoCAD.
If you have concerning to automate your design later, it means you jaust only give some design change for your previous design and the CAD should give you this result, then AutoCAD is the answer, it has AutoLISP and C++ Application Programming Interface (API), that you can costumize it.
I hope, this would make it clearer for you.
regards
Most RC detailing is generated from design programs such as Masterseries or CADS but there are add on packages to AC and stand alone detailing suites.
Try these links: -
http://www.masterseries.co.uk/
http://www.cads.co.uk/front.htm
http://www.nemetschek.com/
http://www.multisuite.com/welcome.html
Hope these help.
