Mating Gears
Mating Gears
Hi, I am having a problem mating gears. I am trying to figure out how to do this with only mating and expressiosn if at all possible.
Right now I have my 2 gears assembled and rotating around there center axis. I am using an expression to link the to and have them rotating in the same direction. I am trying to get them to rotate in opposite directions at the same time.
I do not need them to actually be mated, as long as it looks as they are mated and are moving in the correct manner.
Thanks!
Thanks!
RE: Mating Gears
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
RE: Mating Gears
RE: Mating Gears
ANG50=ANG25*2
Now change the value of ANG25 and the gears should move as required. Now you will have to make sure that they are rotating in the proper direction and so you may need change the sign of the above expression to accomplish that:
ANG50=-ANG25*2
Now to actually animate the assembly you'll need some what to quickly edit the expression value for ANG25. Below is a link to a GRIP program to do that. I'll reference the Source Code in this note and the Executable in the next.
John R. Baker, P.E.
NX Design
Cypress, CA
RE: Mating Gears
John R. Baker, P.E.
NX Design
Cypress, CA
RE: Mating Gears
Thanks!
RE: Mating Gears
John R. Baker, P.E.
NX Design
Cypress, CA
RE: Mating Gears
Right now, I have both gears as parts in a final assembly. There center lines are aligned to a common datum plane and there faces are aligned. The distance between there center lines is also constrained.
I can not seem to figure out how to get them to rotate in opposite directions. Should I be using the expressions to mate them to eachother, or a common part inside the final assembly? When I am mating do I reference a datum axis or what were you using as your reference for the angle?
Thanks!
RE: Mating Gears
John R. Baker, P.E.
NX Design
Cypress, CA
RE: Mating Gears
RE: Mating Gears
This is my first time using this GRIP program. I have gone NX open grip, but am not sure how I am supose to get the program to actually run in NX4.
Any help would be great. Thanks again!
RE: Mating Gears
Do a File -> Execute -> GRIP... and select my GRIP program.
John R. Baker, P.E.
NX Design
Cypress, CA
RE: Mating Gears
