set default font in NX5
Does the default font have to be set in each seed file, or is there a customer default that works? I have changed the default in Drafting>General>Lettering fonts, and it has no effect. I have changed it in the ugii_env file and it has no effect. By "has no effect" I mean that when I start a new file from "blank" the font does not reflect my change.
Thanks in advance!
Thanks in advance!
RE: set default font in NX5
No, what you need to do is go to Drafting -> Genreal -> Standard and either edit one of the existing standards or create a new one where you have assigned new default Fonts for the different types of text, such as Apprended, General, Dimensions, etc. Note that editing a standard or creating a new one and making it the default will update all new file created whether you call for the 'Blank' (seed part) or one of the other for organized templates (seed parts) EXCEPT in the case where you are using a Drawing Template (seed part). In that case unless you also go to Drafting -> General -> Drawing and set the 'Drawing Settings' option to 'Use Settings from Standard' it will NOT overide the existing Drawing Template (seed part) settings.
If you follow the procedures outline above, including setting the 'Drawing Settings' option, there is no need to edit your existing or the system supplied template files (seed parts).
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
Believe it if you need it or leave it if you dare. - Robert Hunter
