Display Name of Sketch Entity?
Can anyone tell me how to display the name of each sketch entity within the sketch?
Thanks.
Thanks.
---SW 2008 SP1.1---
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Display Name of Sketch Entity?
Do you mean names like 'line' and 'arc'?
Jeff Mirisola, CSWP
Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
Yes. When you draw a line SW dosen't SW give a name you can display?
---SW 2008 SP1.1---
Thanks.
---SW 2008 SP1.1---
What are you actually trying to achieve? There may be a slightly different way to reach your actual end goal.
Jeff Mirisola, CSWP
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
Since SW offers UP the info. I'm assuming it does for a reason. Also the info isn't even displayed in the properties manager for the line.
Thanks.
---SW 2008 SP1.1---
---SW 2008 SP1.1---
It is much simpler for users to click on graphical entities rather than keep track of their ID's, and have to type them into a selection box.
Maybe the ID's could be used in API macros if non-graphical manipulation is required.
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
BARM,
Did you have a specific use in mind for the entity names?
When you select Entities it displays the names in the Property Manager.
If you Box select all your geometry you can locate each item by selecting it in the Property Manager and looking for it to highlight on screen. You may need to be in Add Relations to get the item names or just select more than one item.
Michael
Did you have a specific use in mind for the entity names?"
No. I just came across the info and wanted to know it's function or display methods.
Thanks.
---SW 2008 SP1.1---
