Motor Heating
3
Motor Heating
Motor Heating
I attended a lecture on “Circuit Imbalances” where the presenter discussed a relationship where; e.g., in 3ø motors:
   Per-Unit Temperature Rise = 2 x (Per-Unit Voltage Imbalance)^2
Is this correlation referenced in an IEEE or NEMA standard or guide?  The presenter was unaware of its origin.
RE: Motor Heating
That relation is given in "Managing Motors" 2nd ed by Richard Nailen page 4-19.
He mentions that it comes from "NEMA and various researchers"   (nothing more specific.
RE: Motor Heating
And by the way.....
WELCOME BACK!
RE: Motor Heating
Yes, welcome back.  I remember your handle from several years ago when I had a different handle.  I recently returned and tried to log-in and forgot mine but apparently you remembered yours.
From your member activity it looks like you fell of the face of the earth starting sometime in 2005 till about now!
RE: Motor Heating
Hiya busbar,
Nice to see you back here. Been a few years hasn't it?
RE: Motor Heating
Hi busbar, go to see you back also. Now, we just need to find out where jbartos went!
RE: Motor Heating
That was supposed to be 'GOOD' to see you back!
RE: Motor Heating
Back to his village. There was a vacancy which needed filling.  clown
RE: Motor Heating
I've just been using busbar's old answers. rednose
Nice to have you back, busbar.
RE: Motor Heating
Welcome back busbar. I often wonder why people drop off.
Well, some people anyway... I was always curious if Jbartos was related to Frank Bartos of Control Engineering magazine.
gepman, that explains a lot. I thought you stepped in being a little too savvy for a newbie. What was your old handle?
RE: Motor Heating
Thanks for the positive responses, folks.
And thanks especially for the reference, e-pete.  I'll look that one up.
RE: Motor Heating
Hello.
I would like ask other Q.
What is formula ( if any) for realtionship between current unbalance (imbalance) and Temp rise/ heating of motors.
Regards.
Slava
RE: Motor Heating
It comes from:
For example,
1% volt unbalance -> 2% increase in temperature rise.
2% volt unbalance -> 4% increase in temperature rise.
3% volt unbalance -> 18% increase in temperature rise
4% volt unbalance -> 32% increase in temperature rise
I believe the relation applies the the temperautre rise at near full load which is the one of most interest in derating.
In Nailen's book, he says that  the above relationship can be combined with an assumed load / temperature relationship to develop a relationship very close to the published NEMA MG-1 derating curves curves for voltage unbalance.
The load / temperature relationship that he gives is
1 + [fracitonal increase in temp rise] = [fractional increase in load)^1.7
(I believe this is based on fractional changes near full load).
I have plotted the method to combine these relationships to give the NEMA derating curves here:
http://home.comcast.net/~electricpete/eng-tips/UnbalanceDerating.xls
(you don't have to enable macro's - answer no)
You can see it's not too far from the NEMA derating curves which you can see on page 17/30 here:
http://www.joliet-equipment.com/pdf/techinfo/EASAHandbook.pdf
RE: Motor Heating
By the way, I have to say it again.
WELCOME BACK  !!!!!!!!
WAVEYROLL1CHEERSWAVEY2flipWIGGLEWAVEY3roll2
RE: Motor Heating
Hello.
ElectricPete, thanks a lot, you are great!!!!
As EE, to one good answer I have two additional Q's smile.
Are possible say that relation between unbalance voltage and unbalance current is lineary and about
pu U2 ---- 5 x pu I2?
Best Regards.
Slava
RE: Motor Heating
Slavag,
Have a look at Chapter 19, Section 19.7, of the Areva NPAG which you may find interesting, as it answers your question. The relationship is basically the ratio of starting current to rated current, 5 in your example.
Marmite
RE: Motor Heating
Hi.
Marmite, thanks a lot to you too.
Today is day of stars.
Best Regards.
Slava
