Dimension disappearing
need help, don't know why every times i click on a dimension it disappear.
senario: i started a new drawing, add std views, some dimensions imported with the view. i went in to clean-up the dimension. when i select the dimension to drag it's disappear. However, the dimension property dialog box pop-up on the left side. the dimension disappear from the drawing, can't bring it back.
thanks
thanks
RE: Dimension disappearing
Flores
htt
