SW2008 Crashing
SW2008 Crashing
SW2008 Crashing
We are using SW2008 and everytime I try to plot something the software encounters a problem and has to close.  I can print out a part drawing on a 8 1/2 x 11, but if I switch the printer to the plotter it crashes.  I have tried plotting on another computer that has the same software and it crashes.  I was able to plot a document from MS Word, so this proves that it is the software.  When we were using SW2007 I was able to plot fine. Has anyone else encountered this problem?
RE: SW2008 Crashing
So--the usual question--what SP are you using?
Jeff Mowry
www.industrialdesignhaus.com
What did you dream?  It's all right--we told you what to dream.
    --Pink Floyd, Welcome to the Machine
RE: SW2008 Crashing
Do you get a print preview prior to printing to the plotter?
About 90% of the time with Plotter issues it turns out to be a bad Driver. Try updating your Driver.
Scott Baugh, CSWP pc2
www.scottjbaugh.com
Quote:
"If it's not broke, Don't fix it!"
RE: SW2008 Crashing
Theophilus - SP2.1
SBaugh - When I try to print preview it crashes also.
Steven Cobb
RE: SW2008 Crashing
Just to follow up.  We updated the driver and now we are plotting fine.  I hope this helps anyone that comes across this problem.  Thank you SBaugh for your help.
Steven Cobb
