How can I delete a block with three objects that I cannot see?
Somewhat new to AutoCAD, I am converting Italian drawings to FEDA standards. Several challenges exist and sometimes it means redrawing from scratch.
Question: How can I delete a block with three objects that I cannot see. I then want to delete its layer as part of clean-up.
The block preview window shows me something I did not draw, so it must have come with a copy from the source drawing.
RE: How can I delete a block with three objects that I cannot see?
can you use "qselect"? Maybe you would find the objects.
Or you use a 3rd party tool:
htt
Or you export all wanted objects by "_wblock"
Lothar
ADT 2004
list --> all --> remove --> (select what you want to keep, with a window or crossing) --> enter
They then check the list to make sure it only includes what they want to get rid of, then:
erase --> previous --> enter
