Scale drawings
Scale drawings
Scale drawings
I have a drawing scanned into my computer and its saved as a jpg. On the drawing there is a dimension marked. Is it possible to somehow import and scale the jpg file so that the dimension shown on it will corrispond to the dimensions in autocad.
I think that makes sence!!
I want to save all the fidelling around scaling the drawing buy 0.00035424% in order to get it set up correctly so i can then trace over it. i can import pictures but i dont know how to scale them.
the origional is well over 100 years old so not much chance of getting hold of the origional .DWG file!!
Many thanks in advance.
Peter
RE: Scale drawings
draw line over existing image of old drawing scale
SCALE -> select image frame and line
base point -> end point of line
R (for reference) -> select the two end points of line
enter known length of scale.
hope this helps
Lee
Intel P4 3.0 GHZ
512 DDRAM
Win 2000 Pro
Autocad 14, 2002 with EP 2.3.1
Autocad 2008
RE: Scale drawings
If the original is 100 years old, I'd love to see the original DWG file.  That would be fun. ;o)
RE: Scale drawings
OTHGWayne,
That's why it is a good thing that OZZY stated:
IMAGE of old dwg
RE: Scale drawings
OOPS, my bad :0)
RE: Scale drawings
OZZY84,
I had the same problem (a scanned 1970's vintage drawing).  To use your excellent tecnique, I had to first select all (Edit > Select All), then followed your procedure.  It worked perfectly.  Thank you
David
RE: Scale drawings
Ok guys thankyou very much. It took a couple of goes but I think I have it figured now.
The internet really is a wonderfull thing.
Peter
RE: Scale drawings
Don't you may have to repeat the scale command a couple of times to get as close to the dimension stated on the drawing.
