Script to remove part of a text block?
My company is doing a lot of updating right now, and there is some information on all of our (50,000+) prints that needs to be removed. While I can do some really nifty things w/our other cad program, I'm pretty clueless when it comes to doing the more detailed stuff w/AutoCAD. I've linked 2 examples below- is there a way to script removing the last 2 items (routing and send to) in the blocks on the bottom left corner?  We have prints set up both of the ways shown.
http://www.unforgottenpath.org/aza/MM241416.WLT.dwg
http://www.unforgottenpath.org/aza/MM762422.UBT.dwg
RE: Script to remove part of a text block?
Yes, with some custom programming.
In one drawing, the "SHIP TO: WELDING" is a attribute value in a block insert; in the other drawing "SEND TO: SHIPPING" is the last line in some MTEXT.  A (lisp or VBA) routine would search for the mtext & delete the offending text, and search for the block insert "routing" and clear the attribute value. Now include this routine in a batch program such as Scriptpro to run on all the drawings.
Thank you for the reply- I knew it *should* be relatively simple, but since I don't work with AutoCAD in depth, I wasn't sure where to start. Time to get started on implementation!
