unstabilized crude flow measurement
ultrasonic have no chance with boiling fluids like unstabilized crude, or crudes with small gas bubbles mechanically entrained exiting the primary separators--- as most oil facilities operate with at 2 to 3 stages of separation I am curious why more often of not US have been applied and get bad feedback. Good old fashioned meters work however can anyone point in direction of successful meter technology that you have had reliable and consistent readings with for measurement of crude and crude/water mixture with entrained gas bubbles i.e. for liquid lines from primary separation stages, and manufacturers?
RE: unstabilized crude flow measurement
For example, a Positive displacement meter is likely to be virtually immune to the gas bubbles. That is to say, if 1 litre flows through the meter then 1 litre is registered whether it is 1 litre of liquid or 1 litre of liquid plus air.
Some corolis meters will measure 1 kg of liquid but suffer an error when that 1kg is a mix of liquid plus air.
Of course, the problem is to know how much of the fluid is crude and how much is air.
Some US meters are said to be quite good with entrained bubbles. Hence, if they, like the positive displacement meters can report the volume accurately then it only remains to use an Entrained Gas Density meter (+/-1.0% accurate fro fluids of from 0-100% air) to determine the mass flow of crude (actually the mass flow of liquid plus air; but while the volume of air is significant, the mass isn't and hence the mass measured can be accepted as the mass of crude.)
Work has been going on with Coriolis meters. The results are said to be promising. I think, so far, some 10" meters have been tested and found to be 3% accurate with entrained air.
JMW
www.ViscoAnalyser.com
The coriolis meters can tell you the total mass that goes through them, but they have no way of saying what is water, oil, or gas. try this link to see how they can be used. http:
http
In a system where you have crude oil plus air mass flow measurement is achievable with accuracies of 1.0-1.2%.
A volumetric meter will record the volume flow total and rate accurately. Of course, what you don't know is what fraction of that volume is air and what is crude but if you want mass flow, no problem, you don't care about the volume fraction.
Note that a brooks style meter is used for liquids and for gases, same principle.
The problem is to measure the density since you need density and volume to get mass. Most density meters have a problem with entrained gases and that includes most coriolis.
The "give-away" is that while a liquids only density meter will return 0.03% accuracy, an entrained gas density meter will return <1.0% accuracy and this is the dominant error in mass flow.
So, by combining a pD meter with an EGA density meter the mass accuracy is 1.0-1.2%. Not ideal, but pretty good considering that in trials of one coriolis meter the mass accuracy with entrained air is 3.0%.
But "you cannot measure two phase flow, period..." No, you can.
Of course, if one of those phases is a mix of two or more different liquids then you have a problem. Thus, if the crude has a variable water content then establishing the mass flow of crude from the mass flow of crude plus water is more difficult if there is air also.
JMW
BTW...US flow meters are not very accurate. Go with a MAG tube...uber results.
h
Of course, I haven't been able to establish if this is a % reading error or a cumulative error nor to what extent the fluid is aerated nor if it is a fine dispersion of bubbles or a chaotic mix of bubbles and pockets, but those involved in the tests seem persuaded they can do better. I think Invensys has an article out claiming success for these trials.
JMW
In the early seventies I used to observe local circular chart recorders on steam condensate using an orifice plate. The flashing caused the ink to paint the chart like it was air-brushed instead of draw a line. You could still see an average that could be interpreted as the flow rate. An electronic signal could dampen that same signal to provide a steady reading. Others can comment on the precision of such a measurement. I suspect that a similar noisy signal would occur on liquid with entrained gas. The orifice and dp transmitter could measure the flow. The precision could be questioned.
What we've done in the past is install a Micro Motion with a GVF (Gas Void Fraction) meter (Cidra Sonatrac) downstream of the Micromotion and have been able to back out a relatively accurate volumetric flow rate.
"If experience was always the only factor, how would we get to the moon?"
http://www.piping-designer.com
