ALTERNATIVE TO RAYRIM
Does anyone one know of a trim similar to Raylock's Rayrim? It is a edge trim that has a hot melt glue on the inside. When it it is applied it shrinks in place and the glue melts forming a strong bond. It is a whole lot better than trying to put supper glue inside plain rubber trim.
Is there something with a pressure sensitive adhesive instead of a hot melt?
here is a data sheet that explains it better.
http://www.rayservice.com/file/151/
