Small holes in elevated slabs
Does anyone know what is typically used to fill small holes in elevated slabs, say a 3" diameter max?  Could it be as simple as roughing up the edges and filling in with a non shrink grout such as Duragrout?
RE: Small holes in elevated slabs
I would also use a surface bonding agent.
Your "simple" approach is all that is required for small holes.  The grout will be its own bonding agent.
