Process address space warning?
Yeah, it's the new guy again.
I am working on a rather small welment assembly and I just started getting this message:
"Your Inventor session has used up more than 80% of the available process address space (2048 MB). It is highly reccomended that you close down some documents before proceeding further."
I only have this drawing opened and have closed just about every other Windows program. However, the message keeps re-appearing. If there a way to increase the process address space? Or is there another fix?
Thank you,
Dominic
RE: Process address space warning?
What do the numbers in the lower right hand corner of the window say when you get this message?
David
Thanks for replying.
They said "42" and "10". But once I closed Inventor and reopened it again, they went back to "42" and "2".
I also found out that I do NOT have 4GB as I previously thought. I only have 2 GB RAM. I'm supposed to get 2GB more pretty soon. That should help out a lot.
