Determining Fb for Aluminum shapes
I'm trying to find out whether using Chapter F of the ASD Steel Construction Manual to determine Fb and Fv for aluminum is acceptable or not. Thanks for the help
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Determining Fb for Aluminum shapes
Aluminum has its own design manual. Additionally, beware of welding with aluminum as it lowers the allowable Fb significantly (at least in the region of the weld).
They have their own specifications titled Specification for Aluminum Structures and Aluminum Standards and Data.
Also - aluminum has a lower E so deflections are a bit higher.
This doesn't have to be real precise (ie....this is not a commercial structure, and it's for components and cladding) so is using .4Fy or .5Fy a reasonable guesstimate for determining Fb?
Maybe I shouldn't worry about stresses as ultimately, deflections are going to govern........and I understand that the E is much less than steel so deflections are much higher.
Thanks again.
I believe the publications are produced by the Aluminum Association, Inc.
Good Hunting...
Mike McCann
McCann Engineering
