Low pass filter for intermodulation setup measurements
Hi all,
I have to do some second order intermodulation measurements for an AM buffer. That´s it, the block just after the antenna and before the receiver.
I need a band pass filter or a low pass filter to make sure that when I combine the two generators I do not introduce any intermodulation.
The two tones are 800 and 900KHz respectively. I tried to design myself the low pass filters but with no luck. I also tried to find SMA filters in minicircuits but the do not cancel the second harmonic, as the minimun starts at 1.9MHz.
Does anyone know any company where I can buy the appropiate filters, o any other suggestions?
Thanks in advance!
RE: Low pass filter for intermodulation setup measurements
I do not know what good a lpf would do you.  You need isolation from one source to the other.  Really narrow 800 and 900 KHz center frequency bandpass filters would work.  A 15 dB pad on each source would work too, although you might have to boost the source's powers first.
I guess I am assuming a third order intermod test from the 2 tones when I say the above.
