Hospital Ocupancies NFPA 13 02
New Hospital how would you classify the following based on NFPA 13, 02
Mechanical Rooms: Ord Gr 1 or 2?
Diesel Generator Room within mechanical room: Ord Gr 1, 2 or EX Haz 1 or 2?
Day tank is about 150 gallons for a generator.
I am thinking mechanical rooms should be Org Gr 1 but the Generator Room should be Ord Haz Grp 2 or higher.
Current design is all Ord Grp 1.
Tom
Tom
Fire Sprinklers Save Firefighters’ Lives Too!
RE: Hospital Ocupancies NFPA 13 02
You are well protected with a generator room designed for OH2. The fuel (if stored) should be in a UL 142 aboveground storage tank, which has minimum 0.25 inch carbon steel walls and a 0.37 inch carbon steel head. If it's a sub base tank, the metal thicknesses are even greater.
My opinion of course...
the generator is whole new issue, ie storage of fuel location of storage, volume of storage, size of generator... does it contain the switching equipment and electrical panels
ect. ect.
hope this helps
