Render beam profiles in CAE/Results-mode
Hello everyone,
does anyone know how I can display the beam profiles (i.e. the 3D-shape of a beam) in the Results Viewer mode of Abaqus CAE? In the Part and Assembly module of the Preprocessor it is easy, but I did not find this option anywhere in the postprocessor!
Thank you in advance for your help!
Lorenz
Lorenz
RE: Render beam profiles in CAE/Results-mode
View - ODB Display Options
On the first tab there is a section called "Idealizations". Check the box and choose the scaling factor.
BTW This is V6.7EF (released at the end of last year)
