Control Valve Repair: The pressure test
What is the applicable code to support a pressure test after welding repair in a control valve body. We review ASME B16.34a but this code refers to New valves, Can we use this procedure? Do you know another code or practice more specific? I think that is not convenience use it (B16.34b) because the body has less thickness due the use.
Thanks in advance
Thanks in advance
RE: Control Valve Repair: The pressure test
Patricia Lougheed
