how to turn nitrated-steel cylinder for repair job?
I’m having problems to get a sufficiently smooth surface and trouble with very short toollife.Tried ceramic inserts and diamondtipped.Material to be turned are injection-cylinders used to inject dies with thermoplastics at very high pressure.Size is upto 4000×300×140mm(lenght×outer×inner).These cylinders are nitrates but the inner is worn,and the most of it is to be replaced by a bimetallic piece.
RE: how to turn nitrated-steel cylinder for repair job?
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Save water Drink Beer
Ed Danzer
www.danzcoinc.com
www.dehyds.com
What you need is a grinder attachment for your lathe. It attaches to the toolpost and has an electric grinder wheel.
Don
Kansas City
