Thread Relief
Thread Relief
Thread Relief
What is the Proper way to callout "Thread Relief" on a drawing.
RE: Thread Relief
Not sure if it will make much difference but what drawing standards do you work to and what thread form?  Also male or female threads, or both.
For instance in the UK on male UN threads there was actually a spec (BS 1936 maybe) that addressed this to some extent, if I'm understanding your question correctly.
KENAT, probably the least qualified checker you'll ever meet...
RE: Thread Relief
BS1936 part 1 is for inch threads.
http://www.standardsdirect.org/standards/standards5/StandardsCatalogue24_view_846.html
BS1936 part 2 for metric.
http://engineers.ihs.com/document/abstract/ZVREFBAAAAAAAAAA
From memory it essentially defines the tool to be used, based on thread size, which in turn gives you the dimensions for the actual cut-out.  It's a bit backward from normal drawing practice but there you go.
As I recal from working with part 1 it gives some details on how to call it out on the drawing, but with more consideration I'm not sure it fully answers your question.
RE: Thread Relief
I'm not aware of any standards but in my experience you call out the length and diameter, plus any corner radius if desired. The length should correspond to a standard cutting tool and the diameter should be below the root diameter. You should be generous with tolerances, and try to use the same relief for similar threads.
RE: Thread Relief
My experience with actual "thread reliefs" was with a Mil-spec defined by the FED-STD-H28.  If this is what you are referring to, I would flag the geometry to a general note, referencing all thread reliefs to the Mil-spec.
If this is not the case, reference ASME Y14.6-2001.  I believe it shows multiple methods of dimensioning and representing complete and/or incomplete threads which would include a thread relief.
Hope this helps.
RE: Thread Relief
I've always used the note "MINIMUM RELIEF REQUIRED TO FORM THREADS" and let the machinist worry about it. If it is critical see above post by Xplicator.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
RE: Thread Relief
I know I'm opening up myself for criticism: If a thread relief is dimensioned, it must be measured. It has been my practice to state on the drawing "MINIMUM THREAD RELIEF" when good workmanship is good enough.
RE: Thread Relief
Xplicator you beat me to it.  I didn't see anything in B1.1 but I took a look at ASME Y14.6-2001 and figures 12 & 13 give some examples.
I've attatched a very rough copy of the scheme in fig 13.
Figure 12 is a larger view and specifices the actual diameter of the undercut.
Madmango & WhitmireGT make a valid point.  What do you mean by 'Proper'?
