Calibration Tank
Calibration Tank
Hey guys,
I am currently making a calibration tank for underwater sensors. I am using a heat exchanger to bring the tank to a certain temperature, once it has reached it the heat exchanger will turn itself off and only the stirrer will run during the calibration. I am trying to calculate the heat shed by the aluminum instruments, after the heat exchanger has been turned off. And for that I need the convection coefficient. Could anybody help me where I can find a reasonable value without having to go through a flow analysis. The instruments can be approximated by cylinders and the working fluid is sea water.
Thank you for your help
Dom
Dom
RE: Calibration Tank
The heat transfer is proportional to Reynolds number, so depends on how vigorously you agitate. Alternatively, free convention is a function of buoyant and viscous forces.
You will need a basic heat transfer text to indicate which calc route to follow given the dominant heat transfer mechanism present.
