re: N2 Gas bottle and circuit - Pressure, sizing requirement
I would like to acquire information on the selection of N2 cylinder  (size,pressure rating, temperature etc) and the necessary components such as pressure regulator.
The application that I am dealing with is to use N2 to pressurize an accumalator up to 70 psig (N2 on one side; water on the other side) in a pump differential pressure instrument loop for testing purpose.  The tubing is preliminary selected to be 3/8".
Also, is a gas bottle required to meet the ASME code?
What codes and standards used in the compressed gas industry in Canada.
Your help is highly appreciated.
RE: re: N2 Gas bottle and circuit - Pressure, sizing requirement
Gas bottles are designed to DOT Title 49 standards (don't recall which paragraph) in the USA.  I think there is a corresponding CT standard for Canada.  As I recall, they come in 2400, 3600 and 5000 psi bottles.
I would use a two stage regulator, with intermediate pressure at about 100 psi or so.
You can find more info here,
http://en.wikipedia.org/wiki/Gas_cylinder
http://virtualpipeline.spaces.msn.com
"We can't solve problems by using the same kind of thinking we used when we created them." -Albert Einstein
