Location of Jockey Pump
Hi All,
Could someone please advise if it is a code requirement within NFPA 20 for the Jockey Pump and it's Controller to be located in the same room as the Fire Pumps.
As you can probably guess I have space issues!
Cheers
DTR
Cheers
DTR
RE: Location of Jockey Pump
BUT, would require the room you stick it in to meet the same building construction requirements as the pump room.
