BOM qty display
BOM qty display
I have an assembly that has several configurations, all of which are the same assembly in different positions. In my assy drawing the BOM is coming in with the configuration name and qty. Is there a way to change the cell to display "qty" only and omit the configuration name. I have tried several ways of changing the text and every time it come back in as soon as I update the drawing
RE: BOM qty display
Bradley
SolidWorks Pro 2008 x64 SP2.1
PDMWorks Workgroup, Dell XPS Intel(R) Pentium(R) D CPU
3.00 GHz, 5 GB RAM, Virtual memory 12577 MB, nVidia 3400
e-mail is Lotus Notes
RE: BOM qty display
The SolidWorks BOM knows what QTY is and wants to make sure your are using the correct config. If you put in a custom header, SolidWorks basically says you are on your own. So your custom header of <spacebar>QTY. or QTY<spacebar> does the trick.
-Dustin
Professional Engineer
Certified SolidWorks Professional
RE: BOM qty display
