Upcoming review, need advice...
I am looking for advice on how to approach my supervisor for a raise. Our yearly review is coming up shortly. The company I work for is great and I really like it here, however there are a few things that bother me. For one, when I go in for my review my supervisor has a number set for my raise, there is no negotiations. The other is that there is another engineer in my department that started 6 months before me and I am sure that we will be getting the same raise. Even though I have out performed the other engineer. My supervisor gives me the difficult projects and gives the other engineer cookbook projects. I like getting the difficult projects, but I think that I should be compensated for what I do. While I am working on difficult projects, the other engineer is filling out forms. What makes the situation difficult is that the other engineer is a female, the only female engineer in the company. I think that my boss is trying too hard to keep us equal in order not to discriminate against her. There are many times when I have asked her opinion on different things and she really does not even know some of the fundamentals. She has never given me any helpful ideas or solutions, where as I know that I have helped her with many projects.
Any advice on how to approach the situation?
I don’t think that I should even mention her during my review, being it is my review. But I don’t like her holding my advances back.
How do I communicate what I expect for a raise, if it is decided prior to the review.
RE: Upcoming review, need advice...
Not almost anymore!
I would strongly advise against saying anything like "I should get a bigger raise than XYZ" or "I'm a better engineer than XYZ" in your review. Comments like that would brand you as a troublemaker, particularly if you are young or new to the company.
David
If you want to get a raise, start advocating for it long before review time. Generally, once review time arrives, the budget is set and your raise probably is also. Also, don't worry about what anyone else makes only lobby for and comment on yourself.
In most companies, the following holds true. Employees are put into pay grades, these employees make some percentage of the mean salary for that pay grade, this is called penetration into your pay grade, each employee is rated yearly and given marks like, does not meet expectations, meets expectations, exceeds expectations, etc. Based on your pay grade, penetration into your pay grade and your rating during a review your raise is calculated. End of story.
What you want to do is get on your Supervisors radar screen well before review time that you want more than the standard raise. During the year put in some extra hours, volunteer for jobs, etc. Around mid-year have a quick one on one with your supervisor and let them know you feel you are going the "extra mile" and ask for their feedback. In order to get a raise, your supervisor has to lobby for you to the folks that hold the purse strings.
All that said, it might not be enough to get a proper raise. There are many threads on this site that make reference to changing jobs to get a good raise. Work the job a couple of years and see how the system responds. Some places give good raises, others don't.
Good luck.
outcome #1:
"Congratulations! You're doing great. You get a 3.5% raise."
outcome #2:
"You really need to improve in a few areas. We can only give you a 3.5% raise."
Not almost anymore!
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
I agree with the other posters that you should never speak / hint of any other person that crossed you. This will make you look katty which is negative. You always want to be on the positve side.
Tobalcane
"If you avoid failure, you also avoid success."
Worry if you are compensated fairly based on your own merit as other have pointed out.
As others have mentioned and your own post says, by the sounds of it your raise amount is determined long before the review meeting.
My biggest raises came basically out of the blue, I'd gone out of my way to go above and beyond and got rewarded for it. In fact my biggest wasn't even on the yearly schedule!
Talk to your manager about what you need to do to advance yourself, don't just talk about pay though this is probably your main concern.
As others have said, a lot of the time the way to get a raise much above inflation is either a completely new job or at least some change at your current job such as new duties etc.
KENAT, probably the least qualified checker you'll ever meet...
TTFN
Heck, last year my manager juggled numbers to give me the biggest he thought he could withoug hitting other staff and then got nocked down a little by HR/senior managment so I didnt' even get the 4%.
I wouldn't make any comparisons with another employee to justify a higher raise. For all you know, the other person is a friend of someone higher up the corporate ladder.
The ramifications of bringing up coworkers in workplace discussions is something that always must be carefully considered no matter what the circumstance, even if you think you're being complimentary. What if the boss really irrationally hates the person you think is doing a great job and you praise that person? You've just been lumped in with someone the boss wants gone.
Professionalism in workplace matters breeds a good career. Familiarity in the same matters can go horribly wrong, no matter what the intentions.
don't worry about what someone else does or makes. that is really none of your business.
You never know what they have negotiated up front.
Example: Does the company provide any reward for getting my EIT or PE?
What classes can I take to improve my skill set and add value for the company?
Are their any certification classes available?
What's even more disturbing is the boss dictating what percent you will give to the United Way. I never had that pressure in all the other companies I worked for.
TTFN
TTFN
Hg
Eng-Tips policies: FAQ731-376: Eng-Tips.com Forum Policies
I never wear street cloths to work
